RCU Forums - View Single Post - GR130
Thread: GR130
Old 06-20-2013, 01:49 AM
  #70
athome
athome's Avatar
Default RE: GR130
I also use a remote stand and a simple trick before actualy starting the engine is to switch on the thrust indicator, grap the engine by it's mounting and than pull at least 120% of max rated, in this case you should read 150N (appr. 15kg) while the stand still holds.
Right and good hint! the stand itself i've tested this way but not with the trestle... I was surprised that it worked flawless with the new Parameters!
regards Lukacs
