ORIGINAL: BHolsten
Does anyone have the correct program settings for the Spin 99 when using a Hacker Q80 x 14XS they would share. I seem to be experiencing inconsistent settings at the idle/brake speed and I seem to be consuming much more Mah during a flight. I have the controller set to Auto currently, because the settings I was previously running in the fixed manual configuration decided to do strange things like not Arm the ESC or it would try to start and stop?
I flew it yesterday and I have to keep chasing the trim, so the delay (lag time) on the brake doesn't get wider during a flight.
Any advice would be appreciated.
Bill
Bill, here is what I use, the bar between lines indicates an arrow. You start at top of the program in the box (assume you have a Jeti box)
Controller type
Spin 99
Main setting
Temp protection 100 C
Brake Manual setting
Dead time 0.1s
Initial breake 20%
End brake 30% (Q80 needs more increase to suit)
Brake speed 0.7s
Operation mode aircraft
Timing (C50 cero deg) Q80 25 deg
Frequency 8khz
Acceleration 0-100% 1.0s
Accumulator type
Number of cells Lixx 10
Lixx cut off
pr cell 3.0
Off Voltage set 29.94
Cut off : slow down
Initial point : fix
Fix initial point :1.10ms
End point : 1.92ms
Auto inc. Endpoint ON from 1.92ms
Throttle curve LINEAR ( make curve in Tx)
Rotation left
Timing monitor : OFF
Setting thr R/C: OFF
Best regards
