RE: Jetti Pro Spin 99
"I am guessing, I can use my WATTS up meter to measure the pulse with also or should I use the Spin box exclussively?"
I'd use the jeti boxthen you can be sure that the nominal msecs will match, if you see what I mean!It's easy to measure the Tx pulse widths with the jeti box-just power up the Rx and Tx, and connect the throttle channel on the Rx to the blue socket on the jetibox, look for "impulse detection", and read off the msecs at low and high throttle.
I've just checked my settings, and with the low setting on the ESC set by the jetibox at 1.0msecs, the actual pulse width from the TX is 0.976 msecs, to arm the ESC.
