RCU Forums - View Single Post - Refresh my memory......
Old 06-29-2013, 12:13 PM
SeaJay
Default RE: Refresh my memory......
Here is the answer I got when I asked the very same question!!
Although my question was slightly different tho, as I was wanting to use the RD8000 as the master, and an RDS8000 as the slave!
"If you want to buddy box the two transmitters together you must use an Airtronics receiver. If you are using a Futaba receiver your master transmitter is modulating negative shift and the RDS8000 is modulating positive shift, therefore, it will not work. Both modulations must be the same. You cannot change the RDS8000 modulation. It will always be positive shift!
Please call us if you need further information. AIRTRONICS TECHNICAL SUPPORT 800-262-1178"
Hope this helps.
Craig
Here is a link to the thread I had on the same subject.
http://www.rcuniverse.com/forum/m_9995012/tm.htm
