RCU Forums - View Single Post - .21 Zippkit ready to go
Old 06-30-2013, 06:21 PM
  #405
Blackout
Default RE: .21 Zippkit ready to go
ORIGINAL: advanced builder
My 21 had a problem with not running after a launch. The engine didn't want to turn a H7 prop. I used a smaller prop from Cromby Zombie Wow I got a tank in Thanks Mark for the use. stubborn me The new to me .67 seducer did start- but my throttle linkage was sticking at the carb barrel. I do have a few CMB .67 carbs to mess with.The 67 SGX rigger ran perfect. minor needle adjustments when I get to Hamilton Ontario Canada
Sounds like a pretty good day! Smaller prop was a good move. I know my NR can have problems with some full blade 1450's if the needle is not perfect. Some engines are more torque and some are more RPM.... Either way you get the job done.
