RCU Forums - View Single Post - cy 23cc engine not starting
Old 07-09-2013, 04:02 PM
96roush
My Feedback: (72)
Default RE: cy 23cc engine not starting
Hi Lars From Norway, yes I just tried it and the pull start stays without turning over engine! engine should have plenty of compression, even tho it shows only 45 Lbs with compression tester! I've taken everything apart and double checked gaskets on carb, and all gaps, .017 on coil! I don't know what the coil should test at for ohms, I've checked mine at static w/ohm meter and I get 5.8 ohms is this in spec? I don't know!! I get spark at plug and it is blue, just put 93 octaine gas/oil mix, still no firing up! I'm about ready to get a new engine!! spark plug has trace of gas, but not flooded!!
[&o]
