RE: Tiny Curare
Ehsan,
Should be rock solid!
I'm surprised your 1 mm can support those weights between rib bays. Must be pretty strong wood.
I find that wood glue (aliphatic type) is a little lighter and easier to use than epoxy for the LE and TE skins. It does require pins though at least on the spar and sometimes on the rib contacts.
David
