RCU Forums - View Single Post - cy 23cc engine not starting
Old 07-10-2013, 02:57 PM
Lars from Norway
Lars from Norway's Avatar
Default RE: cy 23cc engine not starting
Try to put some drops of oil directly into the cylinder, this should fill out the gap between the piston and cylinder wall if the compression is too low. Don't know about how many ohms the coil should have, where did you measure this/on what leads? If you tell me i can check on mine later on.
