RE: CADET/KADET
The Kadet Sr. with ailerons made by cutting away half the trailing edge then using the other half forthe aileron, is an ideal trainer. Done this way the aileron is undersized it will roll but not well or much unless rudder is used. This will get the beginner used to using rudder in the turns as it will not turn well without it.
