ORIGINAL: Goldenduff
Hello,
I too use the Futaba R617FS. I am going to be building a .40 size plane with digital servos. Probably more an exercise on how to do it but I was going so I can scale it up for larger planes. I am planning on a life for the Rx with only the white wire from the servos goin to the Rx. The white and red wires from the servos will go to a seperate larger life. This is purely to eliminate the current going through the Rx.
Basically white servo wires from each servo going to a corresponding Rx channel. Connect all the black servo wires to the neg terminal and all the red terminal wires to the positive?
I havent even tried this so it's a bit cheeky asking for advise but is it as simple as that?!
I'm sure the experts can tell you but I'm putting money on it not being as simple as that...
