ORIGINAL: dasintex
Will the JR Match Box or Channel Xpander work with Futaba or Hitec Servos? Here is what I am trying to do, I have split Elevators with 2 Servos, don't have enough available Channels to put each Servo on separate Channles so I can adjust End Point, and Centering separately with my Radio, which is a Futaba 10C 2.4Ghz Fasst Transmitter, Thanks.
I still use the JR Matchbox when I can't use Channel Mixing. You can connect up to 4 servos to one channel and set Neutral, Direction, and End Points for each servo individually. If you are using Hitec Digital setvos, they can be programmed using the Hitec Programmer.
