Removing excess glue from CA hinge
Hello all,
I've installed my CA hinge for the first time and the control surface is not deflecting as far as it did before I glued it. I'm sure I did was to use to much glue and it built up on the hinge line. How can I remove this excess glue? may nail polish remover, acetone, I'm thinking this. The big question is after removing it with some type of solution will it ruin the integrity of the hinge.
Thank you,
Pat
