RCU Forums - View Single Post - Dynamite .15 cooling head leaking issues
Old 08-19-2013, 11:30 AM
bigcam406
yes,im going to run the engine dry today to put some heat into it and get rid of the moisture.as far the amount of water,there was a lot in the hull.im thinking with all that is going on while it running caused it the water to flood the carb and stall it.the boat ran very well when it did run,and I wasn't really pushing it at all,still breaking it in with rich settings on the carb.when I took the head off,there was water in the cylinder,so it went through the carb.i'll keep you updated,as im going to try the silicone method you mentioned first.thanks for your help
