RE: TF 1/5 Scale P-51 ARF Assembly Thread
Does it appear that the arfs full cowl would bolt on the kits firewall,there by doing away with the difficult shaping of the kits nose? If anybody's got both aircraft could you let us know?
I have a kit version thats on the back burner because I was unhappy with the assembly and shaping of the upper balsa blocks of the nose , I know its not impossible but this might be a easier option.
I have a zdz 50 with a heavily modified bcm muffler that is almost completely enclosed in the lower fiberglass cowl for the kit version which should provide plenty of power ( no 3d) without massive nose hackage i.e. muffler or carb hanging out. So if the dimensions are the same ,firewall to spinner backplate distance , width , etc , it should work ok. Thanks Jay
