Originally Posted by
AGMUSA
This is disconcerting, the information that contradicts the only other available info is coming from the distributor. If I were to need to set the timing to 28 deg btc, I would have to drill and tap two more holes to move the sensor. Perhaps Xairflyer, if you could, check your timing since yours it the only one running so far and let us know?
