Originally Posted by
AGMUSA
AGM warranty for any issure that factory made , so if your engine have Ignition or sensor or others. we do cover it . try do bench run the engin and if sure have problem about timing( like back fire because too much advance timing )or other . we send new one to replace it. it's our job to make sure you are one of our happy user
OK, that sounds good. Like I said earlier, it would not do much of anything, backfire or otherwise. I tried to adjust the timing but there is no way to get it to where it needs to be without drilling and taping new holes which I sure would void the warranty. See post #107, it shows the timing issue. Do I get the people I bought it from involved or deal directly with you?
