RCU Forums - View Single Post - ESM Hawker Typhoon ARF build thread
Old 09-05-2013, 01:19 AM
  #106
LDM
My Feedback: (15)
Every report on the build of this plane was that it needed a ton of nose weight .
Now if you want to reduce that issues it takes some building but you can move the wing , flap servos farther forward in the wing , this requires surgery and adding 4-40 rods ect , but this moves a good amount of weight forward .
Second move the fuse servos forward as well , move everything possible as far as batterys on the nose , all of this helps .
THe MAN review had this plane with dead weight needed close to 17 or 19 lbs , cant remember because it was aprox 4 or 5 years ago
