Originally Posted by
hendocap
Which pipe are you using ? also how about heat , has the header turn blue right away ?
The header has turned a straw colour, the inlet into the pipe has turned blue, and the outlet on the pipe has turned blue. It has a smaller outlet than most pipes. I am going to work on it, may just make up a short muffled pipe as I am not into racing. The pipe I am using at the moment is a
CC Racing "Monster" 1" IS Steel Pipe.
Cheers
