Old 09-28-2013, 02:20 PM
banzaihobby
Default NEW Tamiya Kits !!!
New Tamiya Kits now at Banzai Hobby !!!
TB04 Pro Chassis Kit
The TB-04 PRO chassis is the successor to the TB-03 chassis, and this race circuit chassis inherits its efficient shaft-driven 4WD system with a newly developed, horizontally-positioned motor placement design. The chassis features a number of newly-designed parts and provides a blend of speed and handling that R/C racers are sure to enjoy. The TB-04 shares the same double wishbone, independent suspension parts seen on the TB-03, TA-05 Version II and TRF 416/417 series of proven chassis designs.
DB01RR Chassis Kit
The popular DB01 off-road 4WD chassis receives an update made with racing enthusiasts in mind. This limited edition chassis kit includes a number of Option Parts to give the chassis excellent performance in competition racing. The chassis lower deck is compatible with square-shaped batteries, and the kit includes big bore aeration dampers for high-level off road driving. The front and rear of the model receive fluid filled and sealed gear differential units, reducing the need for maintenance and allowing longer running times.
DF03 MS Chassis Kit
The mid-range shaft-driven 4WD buggy DF-03 chassis was developed from racing data, and the DF-03 MS kit takes its capabilities one step further by fitting a range of option parts. Use of a slipper clutch, assembly universal shaft and center one-way set boost drivetrain efficiency and provide sharp handling, while 4-wheel double wishbone suspension enables a range of settings.
This limited edition buggy features a chassis that is loaded with performance enhancing parts and a Dark Impact body shell with special markings designed by TRF driver Satoshi Maezumi.
The following Hop-Up-Options are included:
53791 DF-02 Assembly Universal Shaft
53924 DF-03 Heat Sink Bar Set
53925 DF-03 Slipper Clutch Set
53926 DF-03 Aluminum Damper Set
53931 DF-03 Center One-Way Set
53940 DF-03 Hard Turnbuckle Shaft Set
53941 DF-03 Aluminum Turnbuckle Steering Rod
53948 DF-03 Aluminum One-Piece Propeller Cup Joint
53949 DF-03 Lightweight Battery Stopper Pin
53984 Buggy Racing Wing
51000 Hi-Torque Servo Saver (Black)
Porsche 911 Carrera RSR - TT02
The Porsche 911 Carrera RSR joins the Tamiya TT-02 chassis touring car entry level line-up. It is a legendary Group 4 car which had a body weighing just 900kg with a 300hp-plus horizontally opposed 6-cylinder engine, and still holds a place in automotive enthusiast's hearts today thanks to its exploits with racing teams the world over. In 1973, the year of its release, it won the European GT Championship, plus the renowned 24 Hours of Daytona and 12 Hours of Sebring races. The works prototype in predominantly silver livery with the Martini stripe also took the checkered flag in the famed Targa Florio race.
Tamiya has faithfully reproduced this sleek racing machine in 1/10 scale on the TT-02 entry level touring car chassis. The TT-02 chassis platform is the successor to the TT-01 as it incorporates many new features to make it even easier for the new R/C kit builder to assemble and learn from. The TT-02 chassis performs well as cornering and overall speed has been enhanced to take advantage of new electronics available on the market. In addition to the TT-02 being an ideal platform to start from, R/C hobbyists can expand its potential by adding many of the Ho-Up-Options available to increase the cars speed and performance.
Ford Zakspeed Turbo Capri - TT02 Gr.5 Wurth
The Ford Zakspeed Turbo Capri Gr.5 Würth joins the ever growing selection of iconic sports and race cars offered on the easy to assemble TT-02 chassis. The car was the result of the tie-up between the legendary Zakspeed racing team and Ford. It achieved excellent results throughout its racing career, the highlight being in the 1981 season in which it blew away its rivals.
Also we have a wide selection of Tamiya TB04 parts in stock and the list is growing!!!
Tamiya TB04 Spares and Hop Ups
Also check us out on Facebook for Weekly Specials and Updates!!!
Banzai Hobby Team
