RCU Forums - View Single Post - temp for engine
Thread: temp for engine
Old 10-07-2013 | 07:15 AM
Sport_Pilot's Avatar
Sport_Pilot
Our engines do not overheat to the point of failure, failure is from lack of oil from a lean mixture. When converted to gas the normal operating temp often exceed the over lean temps on our alcohol based fuel. So the themometer is pretty much useless. Use a tachometer instead. Lean to maximum RPM then enrich till you get a 300 to 400 RPM drop.
