RCU Forums - View Single Post - Control line plane conversion to Radio Control
Old 10-08-2013 | 11:59 AM
vertical grimmace's Avatar
vertical grimmace
Originally Posted by BMatthews
VG, a slight correction. The fat symmetrical airfoils typically used on stunt, sport stunt and combat models will be very gentle at slow speeds. The thickness of these airfoils delays and softens the final stall to the point where they are very easy to fly slowly and give good warning before the break.
These same characteristics show up on the old "fat winged" fun fly models popular a decade or so back.
And of course as with any model a light overall weight to give a lower wing loading value goes a long way to helping.
The key to those fun fly designs was light weight. I guess my point is, if you build it heavy, typical of a lot of RC aircraft, the symmetrical airfoil will give you grief. It will be a non issue if built light.
In all of my years flying CL competitively, everyone was constantly chasing light weight. Hence, the aircraft are designed accordingly. While not the sam as RC, a CL aircraft is perfectly capable of stalling. Especially when pushing the limits.
