I have a G62 I want to use. There is a 90 degree manifold available that lays the carb back on the side of the engine. I have one for another project. I will have to hold this set up over the plans to see if the engine will fit inside the cowl without cutting that big hole in the side of the cowl which is so commonly seen. I got it from a company called fighter aces from England.
