Originally Posted by
76Mustang76
Looking for some help with retracts as im stuck with the plumbing. Nothing in manual to help me. Could someone maybe post a sketch so I can use it as a reference.
Thanks Jeremy
hope this helps just a quick sketch, add the brake line from each wheel,
then a T piece to join two lines, then only one has to go to front, you will end up with 4 lines, one gear up, one gear down, one brake and the last one to the fill valve and air tanks into the + piece.
