I had a couple planes dribbling from the carb as I hang them tail up. It is usually because of fuel still in the tank and it dries out. The bung gets loose, one softened up the balsa in the fuse so much the battery fell out. Tightened the bung and everything was fine, ran much better. I hope you figure it out, probably something simple.
