This is normal for most planes. The proper procedure when you roll a plane is to feed in elevator when the plane comes over inverted to keep it level. then as the plane rolls upright you take the elevator back out. Some planes will also require you to feed in rudder as it rolls to keep it straight, but not every plane will need this.
Ken
