RE: Float set up question
I agree with Jim, the spacing should be about 20%-25% of your wing span. A high wing plane will standup to a cross wind better if the spacing is wide. Another measurement is the distance of the plane to the tops of the floats. Generally, the tops of the floats should be at least 2" below the bottom of the prop arc. This will aid in keeping the spray away from your prop......Seaplane
