Tamiya new RTR Zakspeed Capri WRT - TT02 now at Banzai Hobby!!!
This is a fully factory assembled and ready-to-run R/C model of the Ford Zakspeed Turbo Capri Gr.5 Wurth. The painted and finished super detailed polycarbonate body is mated to the easy to maintain TT-02 4WD on-road chassis platform. The TT-02 chassis features a 4WD drive drive-train with fully independent double wishbone suspension. The pre-installed 2-channel radio gear system operates on 2.4Ghz technology which allows you to run your vehicle anywhere without the need to worry about other R/C enthusiasts nearby.
The TT-02 is the new standard in Tamiya’s entry level cars. The chassis has the battery pack and motor placed longitudinally on the left and right sides of the chassis respectively. The skid-shaped lower deck enables a greater roll movement range during cornering, and the 4-wheel double wishbone suspension is equipped with identical left/right suspension arms and uprights, making maintenance and assembly a simple task. The drivetrain features a motor mount which allows up to 10 different gear ratios as well as front and rear enclosed gearboxes equipped with resin 4-pinion differentials. In addition, 2-types of ground clearance and wheelbase length are possible by altering parts position, making it a flexible machine too.
Please check us out on Facebook for Weekly Specials and Updates!
Banzai Hobby Team
