RCU Forums - View Single Post - giant scale corsair retracts problem
Old 11-30-2013, 05:17 AM
rschaffer
What size battery are you using? I believe it needs to be a minimum 6v battery. I've removed the jumper on mine, and I'm using an 11.1v LiPo with a voltage regulator to bring it down to 9v, and they work fine. On 6v they worked slowly, and a bit jerkily, but still worked with the aux battery plugged in. Also, it looks as if you have the 85" wing corsair, so make sure your jumper is on type 1 and not type 2. Type 1 for the larger retracts. Also, if using a 4.8v battery, the instructions recommend using the jumper in the type 2 position. Hope this helps somewhat...good luck!
