Originally Posted by
hllywdb
I hollowed the wing all the way down to the top skin. I'm thinking of just hot glueing a 6g servo in rather than try and use hardwood mounts. Also going to just use hing tape as control surfaces are 1/16". I figure I can also go light on the elevator pushrod as it's setup to pull for "up" and I won't be doing a lot of inverted.
6g servos are fine, as long as you don't use the very cheapest ones. In my Yellow Jacket I'm using servos from Scanner RC (with one BB, and a weight of 6-7g). Another important thing is to not have any slop (especially on the elevator), pull-pull works very well and it is lightweight. I have never tried using just glue for attachment though...
