Originally Posted by
bluelevel
Goose,
you only need the EX Bus to connect your receivers to external devices like a Central Box or a Powerbox. ZB was talking of the Dual Path with two master receivers bound to the TX but no additional satellite receivers. Slave receivers always have to be connected with the PPM out port routed to the Sat port of the corresponding master.
Thomas
Someone please confirm that I'm understanding this setup correctly.
For a giant scale airplane using 9 channels, I could use 2, R7 receivers, both configured as master and connect their EX Bus ports.
This would give me full RF redundancy and if one of the R7s fails to receive for some reason, it would see the signal from the other receiver, assuming that at least one of them, received the frame correctly? In other words, with the EX Buss connected, as long as 1 receiver received the signal correctly, both receivers will get the information?
