Originally Posted by
wfield0455
Someone please confirm that I'm understanding this setup correctly.
For a giant scale airplane using 9 channels, I could use 2, R7 receivers, both configured as master and connect their EX Bus ports.
This would give me full RF redundancy and if one of the R7s fails to receive for some reason, it would see the signal from the other receiver, assuming that at least one of them, received the frame correctly? In other words, with the EX Buss connected, as long as 1 receiver received the signal correctly, both receivers will get the information?
Wayne,
are you going to use the receivers ONLY or are you planning to use a Central box or Powerbox as well? Only in this case you are right, without the extra device you'll only have seven channels and of course no full redundancy, because you have to connect your servos to one of the receivers. If you are under the assumption that you could wire receivers in series to get more channels, you are wrong. We discussed this topic earlier.
Thomas
