Originally Posted by
pilotpete2
Can you flip one of the flap servos over so that they are NOT in a mirror image. Regardless of what the assembly photo shows, both flap servo output shafts should be pointing to the same wingtip. I'm a bit disappointed to see a company like Sig get a detail such as this wrong. When rigged correctly, you should be able to have the flap servos on a Y harness without having to reverse a servo. The problem is that your flaps are rigged as ailerons, not flaps.
Pete
That would just make too much sense!
