Hi Guys,
I reversed an Airtronics Std 102 servo. It took several tries as the first one didn't work. I just pitched it. The circuit board is soldered to the motor terminals and I used a # 11 blade to cut the circuit board traces. The two wires going to the pot where a lot harder to do because space is pretty tight. You need to reverse the motor terminals and the pot terminals.
Larry
