DECEMBER 6th, 2013
Okay guys!
As promised, here is the Video showing you all the Half and Full throttle Watt / AMP / Under Load Voltage measurements!
Battery Used: Admiral, 4-Cell, 4,000mAH, 40C Discharge, Lithium Polymer!
Steady State Static @ 2:28.49
HALF THROTTLE:
10.25AMPs / 168 Watts / 16.05 Volts
Steady State Static @ 2:37.92 mark it measured:
FULL THROTTLE:
37.78 AMPs / 583 Watts / 15.45 Volts
Okay for Watts per Pound calculations:
583 Watts / 7.3lbs. =
79.86 Watts / lbs.
Here is the Video:
http://youtu.be/auKjtv7Mlbc
