RE: Drill Motor Conversion
Thanks for the help. Right, I ment to say capacitors, not resistors - there is a hugh difference! The motor has "JOHNSON" stamped on the case and some other marking that I cannot read. All the measurments on the motor show that it is a pretty standard size. I'll treat it as if it is a 600 because all the gearboxes, etc. from Hobby Lobby match up. I'll also put a 50 amp or larger speed controll on it. I noticed that anything lower than 12 volts won't even spin the motor, so I assume that it is a 12 volt motor. Does that sound OK?
