RCU Forums - View Single Post - 35% extra rudder servo setup
Old 12-22-2013, 08:28 AM
speedracerntrixie
My Feedback: (29)
speedracerntrixie's Avatar
The Carden was designed to have the servo set up on Pull pull. I'm curious to why you think it would need the weight towards the tail? That airplane should balance just fine with a DA 100 ( not the light version ) or 3W 106 as those were the most popular engines at the time that airplane was designed. Look up the weights of those two engines and compare to the engine you are going to use. You should figure out what to do from there. You would also be able to adjust CG via battery placement and component selection.
