RE: Drill Motor Conversion
I suppose you could roughly work out the Kv of your motor by noting what speed it was supposed to run the drill at, knowing the original gear ratio and assuming the original rechargeable 12v input. I imagine you should be able, and might need, to run it on 12-14 cells or more - that way you might get ~300W out at 20A.
Cheers, Phil
