Old 01-18-2014, 09:06 AM
  #610
Razor-RCU
My Feedback: (50)
Razor-RCU's Avatar
Originally Posted by combatpigg View Post
Many years ago when I first discovered this forum there were a lot of Diamond Dust threads.
I wanted to build one, so it was a simple matter to find out the basic dimensions and I built my own.
Mine differed from the original with the way I built the engine mount and the center section to house the fuel tank and radio gear.....but at any rate it flew just fine.
The "airfoil" isn't critical, just keep it the same thickness as the original and you will be OK.
The original Diamond Dust airfoil with 4 flat sides did the job with the sag of the covering material forming the actual airfoil between the 2 ribs.
I see you are still sharing wisdom in here, how have you been?
