RE: TF 1/5 Scale P-51 ARF Assembly Thread
BNDWTH, One problem you may encounter with the inner gear doors is the fact that the fuse bottom is not correctly made to accept the doors. The full scale P-51 has a ridge that runs between the wheel wells to which the doors are attached. I built the TF 1/5 Kit but elected to not add the inner doors because of this and the shape of the bottom of the wing between the wells. I did buy the plyons, drop tanks, and exhaust manifold from Aerotech. They all work well. I used the interior that TF sold/sells? and it looks good too. For the Pilot I used an officer and gentleman. Plane has a G-45 and flys very well. Should have put in a rear intake engine but I had the G-45. BobH.
