Originally Posted by
yak-54
hi
i noticed a problem when trying to set the throtle cut i set the switch to H and set to ACT
now the throtle arm is not move at all when trying to move it but the throtle cut working
i switched to a different letter (switch) but it act the same
what do i do wrong
thank you ilan
Need to set switch on/off parameters, please refer to examples:
Aurora 9 - Throttle Lock (Hold) & Transmit Yes-No Features & Use.
How to use Icon and/or Switch method which operates when in transmit mode only.
Aurora 9 - Throttle Cut & Idle Down Set-Up..
Throttle Cut Programming - Step by Step.
Aurora 9 - Throttle Curve - Throttle Expo & P-Mix Set-Up.
[NB: Hitec TX use Minus (-) Expo wherever JR/Spektrum use Plus (+) Expo]
ex Hitec USA Support Forum Sticky:
Aurora 9, AFHSS 2.4Ghz Module, Transceivers_Receivers & Telemetry
- FAQ, Setups & Tips
{Individual Links often updated}
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
