RE: Need Help With Engine choice for my Seduction Freestyle.
The directions on the model are horrible, or at least the translation. You are going to have to figure out in what order and how the parts fit together. Make sure you put the elevater joiner in the fusalage before hinging or glueing the joiner in. Just be careful and use some foresight. Overall it is a very quick build and a pleasure to complete as long as you think ahead.
Don't modify anything. The model is perfectly aligned and thought out, if you change one thing there are consequences.
I used thin CA, some wood glue as a gap filler (not much needed), and very light amount of epoxy. I used epoxy only on the firewall, elevater joiner, wing bolt mounts, and to glue the wing halves together.
The Seduction Freestyle is a brilliant performer. It is an absolute spinning machine as it will flat spin even with a way forward CG. Does the most beautiful snaps and wing tip spins you will ever see. This being said if you are new to 3d you might want to practice with a cheap ARF first, but i don't know what your capabilities are.
