RCU Forums - View Single Post - Unequal elevator halves
Old 01-30-2014, 01:05 PM
speedracerntrixie
My Feedback: (29)
speedracerntrixie's Avatar
Jose, what he is saying is that the rear of the fuse is fairly narrow so there is not enough room to mount the servos in the same place on both sides of the fuse. One servo has been moved forward of the other. This was very common when we started putting servos back in the tail of our pattern airplanes and will not lead to an issue of UN-equal travel, the geometry is the same it's just that one servo is farther away from the hinge line then the other.
Check the elevators for warpage, i'm sure you will find it.
