RCU Forums - View Single Post - Unequal elevator halves
Old 01-30-2014, 01:13 PM
opjose
opjose's Avatar
Originally Posted by speedracerntrixie View Post
This was very common when we started putting servos back in the tail of our pattern airplanes and will not lead to an issue of UN-equal travel, the geometry is the same it's just that one servo is farther away from the hinge line then the other.
Yup you're right. Having one pushrod longer than the other is not problematic... as long as all other geometry is the same.
If you've followed Ameyam's other posts, issues and errors though, I'll bet this is a geometry problem.
In the photo one surface merely appears to be higher than the other and the angle of the 4-40 horns he is using does not appear to be equal.
It could be that is an illusion, but I'll put my money on a "user error".
