Originally Posted by
speedracerntrixie
Those look like nylon control horns to me.
Yup you're right.
You can get the full screen image and you can clearly see that they are nylon horns.
speedracerntrixie
Yes they do appear to be in different locations but that is because the elevator halves are not trimmed to match at the root. He has them matching at the tip where the counterbalance matches up with the stab LE.
The elevators have a twist to them. He should match the halves at the root then twist the elevator by hand and re-shrink the covering and keep repeating that process until everything matches.
Yup, I see it now too. The larger image makes it plain. There is indeed a LOT of warp to the elevator itself, and he did NOT attempt to match the trailing edges at the root first as he should have.
