Originally Posted by
SrTelemaster150
This weekend when I have a chance to read through them all. Been way too busy at work, and just doing a casual read through at the moment.
BTW, If you get a die cut kit that was freshly made with sharp tooling, they are just as good as laser cut. Both my Top Flite kits had good cuttings, very few pieces needed extra trimming. On my 1/5th Cub from Sig a few of the laser cuts didnt go all the way through due to the wood density changing in the piece, and needed to be cut out and sanded. I would call it about equal between the two types. Also all you need is a good stiff toothbrush to dust off the carbon from the laser cut pieces, they will stick just fine once the dust is off.
