Matney's Napier Revisited
The wing was removed from the vacuum bag.
Double check the alignment of the cores and the shucks. This is verified by insuring the marker line is straight across the shucks and cores.
Mark a line about 1/8" in front of the shuck at the leading edge.
Use a hobby saw and trim the leading edge at that line. Use a sanding block to insure the edge is straight.
