Originally Posted by
jetmech05
I will start the turn with ailerons but as I add rudder I usually have to reduce ailerons. Now to make a flat turn its rudder with opposite ailerons
Yes, you can make flat turns that way, and it's kind of fun. But it's not the way beginners should be learning to turn. And there are no planes I know of that "need" opposite rudder to turn, which is what the OP was claiming.
