Old 02-19-2014, 09:04 AM
SyCo_VeNoM
SyCo_VeNoM's Avatar
if that engine was new I hope you broke it in properly before tuning, and slamming on the accelerator.
Also here is a tip to make engines last longer take the glow plug out and rotate the flywheel till the piston is as low as it can go in the sleeve. Then mark the flywheel on the very bottom with a permanent marker. After every run make sure that mark is on the bottom so the piston is at the bottom of the engine.
