RCU Forums - View Single Post - Basic Skils: Turns using rudder
Old 02-19-2014 | 09:16 AM
AMA 74894's Avatar
AMA 74894
Moderator
Originally Posted by Top_Gunn
Some day, when the OP is beyond trainers, using opposite rudder in a turn is going to cause his plane to spin. A stall won't make you spin if you're coordinated when the stall occurs, even in a turn, but if you're not coordinated, it can get exciting.
yup, I was going to chime in for exactly this reason, one of the main reasons for having a turn and bank indicator in a full scale airplane... cross control stalling.
a cub, Sopwith, really any model big enough to NEED rudder in a turn is a thing of beauty in a forward slip, but ooooo boy it gets ugly quickly if you forget the first commandment:
"maintainest thou airspeed lest the ground smite thee"
anytime you're feeding in opposite ailerons and rudder, KEEP THE AIRSPEED UP
