Fuse (cont)
I had to build new risers since my old ones were too short to support the crutch at the proper height.
Previously, I already cut out the formers but now they needed all the notches cut out for the crutch and stringers.
After finding out that I like building Bates B-26 with the 1/4" square stringers (more sheeting surface), the formers were marked and cut for that size stringers. I found a 1/4" and 1/2" wide files at harbor freight but found, after cutting out a ton of 1/4" squares in the formers, that one gets proficient at knowing the correct size to cut the notch with the scroll saw. Four formers done, thus far.
The wing saddle supports needed larger notches since the formers are all larger than 1/8" thick.
